Inventor General
Active Member
Message 11 of 11 (145 Views)
Re: Stress Analysis Update & Mesh Control Problem
09-17-2008 05:32 PM in reply to: mechcad8
I ran into the same exact problem with AIP 2009 and this solution worked perfectly. I couldn't do a simple stress analysis update, or preview my mesh. After reregistering the modules, it works like new.
the only problem for me was getting the cmd path correct...for the IT deprived such as myself, i couldn't restart back at the C:, so i found out by typing 'cd ..', it takes you back a folder level. Once back at the C:, you can type in the path, or to be more careful, you can type in a portion of the folder name and hit the tab key, and it will auto-correct to the closest match, i.e., \pro (tab) took me to the program files folder, then \auto (tab) -->autodesk, etc.
Anyways, thanks so much.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
