Inventor Forum
Stress Analysis Help
5 REPLIES 5
donalddalli
576 Views, 5 Replies
(I am relatively new to these forums, so please excuse me if I may be posting this in the wrong section)
I'm having trouble with running a stress analysis simulation on Inventor. I have done various stress analysis on various simple parts but I have never encountered any errors during computation. I am quite sure that the errors arise due the complex geometry of the part, but I'm not sure how I can solve the problem.
The error messages displayed this:
Surface Meshing.
Face could not be meshed. Try to adjust the mesh element size in the indicated area. IF this does not help, consider checking the model for validity, overlaps and self-intersections.
I would greatly appreciete assistance, as this is part of our engineering design project.
5 REPLIES 5
blair
in reply to: donalddalli
It would be wise to post the part, since the error you are showing deals with a meshing issue.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
donalddalli
in reply to: blair
I have uploaded the file below as requested
blair
Looks like the Split-Face is giving the Mesh a problem. Meshed fine with it Suppressed. You should be able to split the model in half (LH-RH) and it will mesh fine. You can even go to a 1/4 of the model as well.
I find it easier to Derive to a "FEA-Model", do my slice/section in it and run the FEA. Since it's Derived and as long as the link is not broken, any  change will update the FEA-Model for analysis.
Delta Tau Chi ΔΤΧ
blair
in reply to: blair
There seems to be a problem with your model along the side flange. This is the root of your problem. It meshes fine doing a LH-RH split, as soon as it splits Top-Bottom this modeling feature issue causing the meshing to fail.
Delta Tau Chi ΔΤΧ
donalddalli
in reply to: blair
I have successfully managed to perform the FEA analysis on the part, thanks to your help! I would like to thank you for your great assistance.
