Inventor General
Active Member
donalddalli
Message 1 of 8 (257 Views)
Stress Analysis Colour Code
257 Views, 7 Replies
05-12-2013 04:46 AM
I have managed to perform a stress analysis on a part (which only 1/4 of it is shown due to its symmetry). Upon running the simulation and displaying the results for Von Mises Stres, all the part has been fully coloured in blue, and there are no signs of any red areas. However, the bar line on the left still indicates that there are areas which are highly stressed. I'm now confused weather if there any areas of the part are exhbiting this type of stress, and if yes, how can I locate the most highly stressed parts? Thanks.
Distinguished Mentor
rdyson
Message 2 of 8 (238 Views)
Re: Stress Analysis Colour Code
05-12-2013 06:47 AM in reply to: donalddalli
I can't speak to the actual analysis but this should answer your immediate question.
JDMather
Message 3 of 8 (235 Views)
05-12-2013 06:52 AM in reply to: donalddalli
The part is very poorly constructed.
Do you have time to re-model the part (with step-by-step instruction) from scratch?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
donalddalli
Message 4 of 8 (234 Views)
05-12-2013 06:53 AM in reply to: rdyson
My problem is, does it make sense to consider that the part will fail, if the area is almost negligable?
Active Member
donalddalli
Message 5 of 8 (229 Views)
05-12-2013 06:56 AM in reply to: JDMather
I believe you are correct. I shall try to reconstruct the part, but this time I will ensure proper construction. Thanks for your help!
JDMather
Message 6 of 8 (223 Views)
05-12-2013 07:04 AM in reply to: donalddalli
Do you need help in identifying the problems?
Start by constraining Sketch1 and all other sketches.
I don't think  you have done your loft correctly.
There are disjointed faces all over the part.
The part is not symmetrical about the origin (but it appears the design intent was for symmetry).
The slice is not symmetrical.
The FEA is not set up correctly.
Active Member
donalddalli
Message 7 of 8 (215 Views)
05-12-2013 07:24 AM in reply to: JDMather
I think I will reconstruct the part from the begininng since I might skipped a few crucial steps, since I wasn't aware of the the problems which might occur with FEA. Thanks a lot for your help!
Valued Mentor
yannick3
Message 8 of 8 (205 Views)
Re : Stress Analysis Colour Code
05-12-2013 07:59 AM in reply to: donalddalli
Hi
you must use the bar color seting and change the max value
see picture
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
