I am trying to split the attached hollow box into 2 pieces using a custom stitched surface (Stitch Surface12 in the ipt file).
Create parting line failed
Splitting Practice.ipt: Errors occurred during update
Split2: Could not build this Split
Interestingly, when I use the "Trim Solid" option on the split, it works perfectly - i.e. I can get either the top half or the bottom half of the box. But I cannot get both using the "Split Solid" option. Can anyone shed light on why this is happening?
Greatly appreciated. Thanks!
Ismail
Solved by WHolzwarth. Go to Solution.
In many cases it's good, if the splitting tool is larger than the body. See file
But extension is only possible to the outside. Why?
Later: I've seen. It's caused by both 171.98 degree angled faces near Extrusion2
Walter
Walter Holzwarth
Maybe there is an easier way? (see attached)
oops, let me try that again.
I just found if I extended the two side surface and the Split Solid can works. Please refer to the attached part. BTW, if you use the Split Face, your original stitched surface also OK.
