I am doing the Inventor 2014 tutorials. In the examine, treat, and solidify the stand tutorial it says to Click the STITCH command, which I did. It then says to click the BODY selection option. There is no Body selection option in the STITCH dialog box. Has anyone else run into this situation? I am stumpped as to how to proceed. Any help will be appreciated. Thanks!
Post the exact url the step where you are stuck.
It sounds like you are being instructed to select a Filter Option.
The CADWhisperer YouTube Channel
Hi,.
As JD said,Please post any link of instruction that you are practicing, pictures of the message given from Inventor or error message,.
Then only can understand the problem and can give solution,.
Bye
Sorry, but there isn't any kind of message or error notice associated with the problem. The dialog box for the stitch command just does not contain the options in Inventor 2014 that the tutorial says are there. I have no idea how I can let you know or make it clearer that the dialog box just isn't set up the way it should be. The STITCH dialog box only contains the option of choosing a surface or setting the maximum tolerances acceptable. The option for Finding the Remaining Free Edges isn't active.
Post the exact url step where you are having trouble.
I never asked for any error message.
Hi,JD,.
I found what exactly sheriff12 says,.
I didn't use this command,.
I found this URL in internet, as he told it is Inventor 2014 tutorial,.
I could not attach the URL, but please follow this steps to find the Tutorial (sorry for making this complicated)
go to 1. http://help.autodesk.com/view/INVNTOR/2014/ENU/
2. Hit search icon,.
3. enter " Examine, treat, and solidify the stand"
4. Hit search.
5. Hit First tutorial (Examine, treat, and solidify the stand)
Please see the attached picture for clearification,.
