Inventor General
Active Contributor
Message 1 of 4 (1,228 Views)
Startup Error [-4.132.0]
1228 Views, 3 Replies
01-22-2013 03:42 AM
Hello all.
I suddenly get this problem on inventor startup. See attachment. I diden't do nothing special, only restarted Inventor. At first sight it looks like we do not have any free licences, but this is not the problem because I managed to start Inventor on another PC using the same windows user.
I encountered this problem again 2 month ago. Then our IT department had to uninstalll Inventor, completly clean the registry and then reinstall again.
Anybody any idea on this?
Thanks.
Inventor 2012
Win 7 64-bit
Dell Precision T5400
Intel Xeon 2,5 GHz
8 Gb RAM
NVIDIA Quadro Fx 3700
*Expert Elite*
LT.Rusty
Message 2 of 4 (1,210 Views)
Re: Startup Error [-4.132.0]
01-22-2013 07:19 AM in reply to: SoulAsasin
Your license manager is timing out, perhaps due to poor connectivity or network lag.  To solve this, you need to set an environment variable to make the license manager wait longer for a response before stopping.
Press your start button, and in the search box type "set environment variable" and hit enter.  Add a System Variable called FLEXLM_TIMEOUT with a value of 100000000 as shown in this screenshot:
___________________________________________________________
Product Design Suite Ultimate 2013, 2014
Work: Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
Home: i7-4770k / ASUS Z87-Pro / 16GB / 250 GB SSD / 1 TB HDD / 3 TB USB3 HDD / 2xRadeonHD 4870 in CrossfireX
Laptop: Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
*Expert Elite*
TravisNave
Message 3 of 4 (1,198 Views)
01-22-2013 02:56 PM in reply to: SoulAsasin
Consider also using the TIMEOUTALL option in an adskflex.opt Options file on the LMTOOLS server.  See my signature line for more information than you can possibly use.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Active Contributor
Message 4 of 4 (1,186 Views)
01-22-2013 10:06 PM in reply to: TravisNave
Hello.
Thanks for the replyes. Your answers make sense. Meen while I updated my graphic cards driver. It diden't instantly work. After an hour it started to work again. So it probably is network lag.
If I encounter this problem again I will try your solutions, to see the effects.
I will reply again, if your answers are solutions.
Thank you.
Inventor 2012
Win 7 64-bit
Intel Xeon 2,5 GHz
8 Gb RAM
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
