How does Inventor decide how to orient the axisis for a new sketch? Sometimes, when I create a sketch on a face of a feature, the sketch sometimes rotates to an odd angle (Untitled.png). I can create a sketch on a different, parallel surface and the sketch doesn't go to odd angles. Why does Inventor do this? How do I edit the orientation? I've attached the part that I'm having the issue in. When I try to create a sketch on the face of the loft, the x/y does things I don't understand. This happens often enough to be very frustrating. I have work arounds, but I would much rather be able to fix the issue, or prevent it completely.
Solved by eveylynne. Go to Solution.
