That was one of my thoughts but
a) I don't think the API is evolved enough
b) If I make a part w/ 10 holes, dim them all, change to 6 then delete the
orphaned dims, and then change back to 7 at some later point I am left
without a dim. Possibly hide the dims? I don't think that's in the API
either...
It seems to me this would be some good functionality to add. If a feature
disappears the dim with it hides also but will reappear if the feature
returns.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Walt Jaquith" wrote in message
news:0701529FC3A6998C119CB5465155C7BD@in.WebX.maYIadrTaRb...
> I would do that with ordinate dimensions if I could. If you delete holes,
> the dims will orphan though. Could a routine be written that searches the
> drawing for orphaned dimensions and deletes them? Then you could create a
> part with more holes than you could conceivably want, and use that for a
> starting point.
> Walt
> "Sean Dotson" wrote in message
> news:E0E147EA03AEB962B4497F9A3D082357@in.WebX.maYIadrTaRb...
> > Well guys I guess that's the way we'll have to do it. Installation
> drawings
> > are sent to the field and given to a contractor or homeowner who maybe
> > doesn't have the best math skills in the world. It would be ideal to
> spell
> > it out for them but if I can't have the perfect solution I guess
something
> > similar to what I'm hearing as the consensus will do.,
> > Thanks for the opinions guys.
> > Out of curiosity has anyone had to deal with non-equally spaced holes
that
> > appear and disappear?
> > Sean Dotson, PE
> > news:466A7ABDEA85C65CF7FB971B2255647B@in.WebX.maYIadrTaRb...
> > > The "DRILL (X) HOLES EQ SPACED" callout is a standard in piping and
> > pressure
> > > vessels for calling out flange bolt hole patterns. We also used it
for
> > > straight-pattern hole arrays. Admittedly, those drawings were a bit
> > > unconventional, but I don't think the callout is all that weird. If
you
> > put
> > > in the first and last hole, with a dim between them, then arrayed one
of
> > > them to fill in the rest, you could drive everything off the length of
> the
> > > part, and the dim for the overall length of the array would never
orphan
> > > because the first and last holes woud not be effected by the changes
in
> > the
> > > array when the part changed.
> > > Another thing we did with straight arrays was dim between the first
two
> > > holes, and add a "TYP" suffix to indicate that the dim applied to the
> > whole
> > > pattern.
> > > Walt
> > > news:ABE46D585BA3220DE8A6CDFD915670BE@in.WebX.maYIadrTaRb...
> > > > OK I know that topic line was a bit cryptic... (and I'm sure this
has
> > been
> > > > brought up before)
> > > > Since I have been in the custom machine industry my whole life I
have
> > > never
> > > > had the need to make IDWs of "standard" parts. However as I get our
> > > product
> > > > engineering group up to speed on IV they will need to produce
> > installation
> > > > drawings of their parts.
> > > > So They make part that is driven by Excel and VBA. Part of this is
> the
> > > of
> > > > installation holes. The # is dependant on the length of the part.
So
> > if
> > > > they make an IDW of the part (with the max # of holes, say 10) then
at
> > > some
> > > > point go back to the part and change this to anything less than 10,
> > you'll
> > > > have orphaned dims.
> > > > One workaround was to dim the first hole then say (equally spaced
10x)
> > but
> > > > that's a bit cheesy. I have another in mind but it's messy as well.
> > > > I'm sure others run into this all the time. How do you work with
it?
> > > > (And they don't want to make a drawing/model for each part. They
want
> > to
> > > be
> > > > able to change the model, open the IDW and then plot to PDF and send
> to
> > > the
> > > > contractor).
> > > > Sean Dotson, PE
