Inventor General
Distinguished Contributor
Message 1 of 16 (544 Views)
Stainless pipe fittings
544 Views, 15 Replies
09-29-2012 04:43 PM
Does someone have a content center library of stainless steel butt weld fittings? I can't believe they aren't already included. Or maybe they are and I just need to be pointed in the right direction. We've started using a lot of schedule 10S plumbing in our systems.
______________________________________________________________
Autodesk Product Design Suite Ultimate 2014
Inventor Pro 2014 - SP1
Win7 Pro x64
Dell T5500; Xeon E5520 2.27GHz; 15 GB ECC RAM; Quaddro FX4800; SSD
Message 2 of 16 (504 Views)
Re: Stainless pipe fittings
10-02-2012 06:20 AM in reply to: dloganbill
Bump Surely we're not the only company using schedule 10S out there. How does everyone else create a correct BOM, mass, etc without them?
Win7 Pro x64
*Pro
jletcher
Message 3 of 16 (495 Views)
10-02-2012 07:21 AM in reply to: dloganbill
I don't use content center library to many issues I have my own  library for this.
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Message 4 of 16 (490 Views)
10-02-2012 07:43 AM in reply to: jletcher
Care to share? Is your library compatible with the tube and pipe program? I'm still amazed that Autodesk left these out. They DID include ASME B36.19M pipe (stainless steel pipe), but they only option for fittings are the B16.9 steel wrought ones. Where are the equivalent B16.9 stainless steel fittings, Autodesk?
Win7 Pro x64
*Pro
jletcher
Message 5 of 16 (485 Views)
10-02-2012 07:47 AM in reply to: dloganbill
You can puplish it to tube and pipe I think. I don't have my drive with me I can upload it tonight or in morning.
James Letcher
Message 6 of 16 (474 Views)
10-02-2012 10:19 AM in reply to: dloganbill
In the past I have just used the steel ones that come with Inventor, then I just fudge the drawing parts list to show the correct material.
I have intended to make a stainless library, but have never found the time to do so.
Are there dimensional differences between the steel fittings and stainless ones?
Message 7 of 16 (471 Views)
10-02-2012 10:22 AM in reply to: cwhetten
Yes. Besides the obvious differences in mass, the larger diameter fittings have different wall thicknesses. Check out this link and compare. Shedules with an "s" are stainless steel. http://www.engineersedge.com/pipe_schedules.htm
Win7 Pro x64
Message 8 of 16 (462 Views)
10-02-2012 11:21 AM in reply to: dloganbill
Thanks for the info.  I never knew what the "S" was for.
I have only ever used them for skids with small-diameter piping (less than 10"), so the wall thickness was never an issue.  And I don't think the difference in material density between carbon steel and stainless steel (on the order of a few thousandths of a pound per cubic inch) is significant (until maybe the 100,000-lb range, and THAT would be a lot of piping).
blair
Message 9 of 16 (453 Views)
10-02-2012 11:34 AM in reply to: dloganbill
I would just copy the nearest / closest CC library into your "My Library" and make/edit the changes is size and material there.
We do a lot with Nylon air-brake in the Pipe & Tube module, I just copied an existing flexible library and did my edits to get what I needed. Much easier than creating a library from scratch (unless you do it about once every 1-2 months).
IV2014 sp1.3 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Message 10 of 16 (443 Views)
10-02-2012 11:42 AM in reply to: blair
Is there a published workflow for doing that? Call me lazy, but I typically lean on the stock CC for standard parts.
Win7 Pro x64
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
