I really have to disagree. I would put money on the fact that an
experienced Inventor user could make a frame as quickly if not quicker than
an AutoCAD user could make all three projected drawings. Especially if
he/she used skeletal modeling.
The other advantage is if something changes the update process is simply
"update". Now try changing all those lines in AutoCAD.
My two cents
Sean Dotson, PE
http://www.sdotson.com
remove all #s from email
"Joe"
wrote in message
news:3dc281cf.2109022@discussion.autodesk.com...
> On Wed, 30 Oct 2002 15:42:33 -0800, "Albert Allen"
> wrote:
> > Frames are ultra quick in a solid and a lot easier to
> >visualize and modify.
> I second that statment. However, I also found that for most frames,
> I can do it much faster in AutoCAD. The reason is that all those
> constraints take time to do, and unless your design really needs the
> parametrics, there is no benefit to doing it in Inventor.
> Joe Dunfee
