Inventor General
Member
dragon_auh
Message 1 of 12 (1,631 Views)
Square to Round Transition Issue...Sheet Metal
1631 Views, 11 Replies
10-18-2011 04:00 AM
Hai All Dear ones,
Here I am attaching a square to round transition duct drawings which is weld assembly & assembly drawing in pdf, This one was made in Inventor from one of our principle maker, I am trying to make this similar in inventor as I couldn’t, I am pretty good in sheet metal able to make the casing well, but couldn’t the assembly of pins and making of cladding sheets on that curved surface, please advice me if there is any easy method to do this,  Help me if you can,
Thanks in advance,
Daniel.
Abu Dhabi.
Daniel.
Autodesk Inventor 2010.
Windows XP.
*Expert Elite*
karthur1
Message 2 of 12 (1,591 Views)
Re: Square to Round Transition Issue...Sheet Metal
10-18-2011 06:06 AM in reply to: dragon_auh
Here is a template that we use for square to rounds.
Valued Mentor
pcunningham1
Message 3 of 12 (1,580 Views)
10-18-2011 07:26 AM in reply to: dragon_auh
Wow, that's a beast. I doubt there's an easy way, but it may help if you include the version of Inventor you're using. I'm guessing you may have to cheat a little on the liner overlaps. Also, it's somewhat unclear what's going on where the upper liner plates transition from cone to cylinder.
Paul Cunningham
IV2008
Member
dragon_auh
Message 4 of 12 (1,539 Views)
10-18-2011 10:36 PM in reply to: karthur1
Dear karthur1,
Thanks for your quick response, I am not able to open the file as I am using Autodesk Inventor 2010 Version, could you please convert the file.......Thank you.............
Daniel.
Windows XP.
Member
dragon_auh
Message 5 of 12 (1,537 Views)
10-18-2011 10:41 PM in reply to: pcunningham1
Hai pcunningham1,
Yeap its really a beast, and yes we have to do some cheating on over lapping liners....but I am facing problem on assembling the pins, doses they assembled in flat pattern or some other way, and also the lines....I am using Inventor 2010 Version,
Please Help me if you can,
Daniel.
UAE
Daniel.
Windows XP.
*Expert Elite*
karthur1
Message 6 of 12 (1,508 Views)
10-19-2011 05:23 AM in reply to: dragon_auh
This one should open in 2010.
*Pro
ampster
Message 7 of 12 (1,503 Views)
10-19-2011 05:28 AM in reply to: dragon_auh
dragon_auh wrote:I am not able to open the file as I am using Autodesk Inventor 2010 Version, could you please convert the file...
Just a reminder, there is no way to "convert" a newer version file to an older version.
I suspect karthur provided you a file created in 2010 or earlier for you.
Member
dragon_auh
Message 8 of 12 (1,499 Views)
10-19-2011 05:38 AM in reply to: karthur1
Dear karthur1,
Still I couldn't open that file its showing the message like below
"Database schema is newer than this version of the software"
Thanks.
Daniel.
Windows XP.
Member
dragon_auh
Message 9 of 12 (1,494 Views)
10-19-2011 05:41 AM in reply to: ampster
Dear ampster,
Thanks & Mr karthur1 provided me the higher version while opening its showing
Daniel.
Windows XP.
*Expert Elite*
karthur1
Message 10 of 12 (1,488 Views)
10-19-2011 05:57 AM in reply to: dragon_auh
Sorry about that.  Try this one.  Pretty sure it was done with 2010.
On a side note, what service packs do you have installed?  You can find them here for 2010.
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9242019#section17
Kirk
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
