Inventor Forum
Square helix??
10 REPLIES 10
Message 1 of 11
3021 Views, 10 Replies
Square helix??
ok so what ive been trying to do for about a week now is make a helix that sweeps around a rectangular prism i was able to make it in solid works but i cant find a way to do it in inventor. any suggestions would help
10 REPLIES 10
Message 2 of 11
blair
Please post a picture of what you are trying to achieve.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 11
in reply to: blair
somethin like this
Message 4 of 11
YuhanZhang
You can try below workflow:
1. Download the attached sample excel which defines the 3D points for creating the sweep path.
2. New a part document and create a 3D sketch.
3. On the 3D Sketch tab, call Insert->Points command.
4. With the Open dialog, choose the excel and click the Options... button to change the Import Options to Create lines.
5. Click OK and Open to create the 3D sketch lines, and then click the Bend command and select each corner point to create the bend so the sweep is smooth at the corners.
6. Exit 3D sketch, and create a 2D sketch bases on XZ plane, and create a circle with its center on origin.
7. Exit 2D sketch, and create a sweep feature with the circle as profile and the 3D sketch lines as path.
Hope  this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Message 5 of 11
Curtis_Waguespack
Hi blmckenzi3,
There are two example models you can find attached at this link:
http://forums.autodesk.com/t5/Autodesk-Inventor/Making-a-rectangular-spring/m-p/3441447
I hope this helps.
Curtis
Message 6 of 11
in reply to: YuhanZhang
that excel file didnt work i got to the insert points commad and selected the excel file chose the create lines option hit open and nothing happened
Message 7 of 11
in reply to: Curtis_Waguespack
how do you make things translucent? sorry im kinda new at this
Message 8 of 11
Curtis_Waguespack
Hi blmckenzi3,
You can do this by extruding a profile as a surface (rather than a solid).
You might use the End of Part marker in the examples at the link to examine how the features were created one at a time.
This is often a good way to learn a new technique. Post back if you have more questions and I'm sure someone will help.
I hope this helps.
Curtis
Message 9 of 11
Message 10 of 11
Thanks everyone! oh man ive been trying to do this for almost two weeks now 😛
Message 11 of 11
in reply to: blair
somethin like this
