For some reason after using Inventor 2012 Professional, When mating two flat edge surfaces together strange offsets with random values or distances are filled into the offset entry box and I have to then change the value to 0.00
This behavior started with no rhyme or reason. The project is significant, and I'm at witts end trying to figure out what happened. Even my backup master assembly files and previous versions are demonstrating this behaviour when trying to do a new constraint of any kind. It even happens when working with a specific .iam when opening a sub-directory folder.
My project master assembly file is 1,620 kb in size and has hundreds of details and sub assemblies.
I'm pulling out my hair due to this sudden behaviour with the constraint issue and I'm to be meeting customers in a couple of weeks.
Any suggestions would be greatly appreciated.
Running 16 Gigs on a 64 bit I5-2500 CPU 3.3 GHz Windows 7
Solved by JDMather. Go to Solution.
Solved by swhite. Go to Solution.
Solved by mcgyvr. Go to Solution.
uncheck the "predict offset and orientation" check box in the constraint dialog. Should be right under the offset entry area... ruler looking icon with the mate icon next to it.
As mcgyver stated make sure this box is unchecked, otherwise you get the default distance that already exists between the surfaces or constraint points.
This is one of the few dialog box options that remain in the last used state.
Can be really aggrivating when you don't realize what is going on.
Thank you, it is profound to have to wrestle with these gremlins and not knowing what they are and how to deal with them.
One frustrating item, Is having to constantly go back and set perspective and shaded with edges in the View Panel any time you save a subordinate .iam in a lower folder and go back up to the master .iam and those associated actions.
Thank you again.
Now and then it comes in handy when you have a part placed where you want but not constrained. Simply check the box and it will give the offset value automatically. Rarely use it, but get models from others sometimes with grounded parts, and makes constraining them easier. I only wish Frame generator and the use default name stayed in the last used state 🙂
y'all need to bury this "feature" in some other menu. this is not useful and is in it's trial stage of development at best. I accidentally checked it on and spent 2 hours today diagnosing the issue (and I see this "feature" as an issue). There's a part of me that wants to bill autodesk for my time on this one.
