I am trying to create a spur gear in Autodesk Inventor 11 using the Spur Gears Component Generator in the Design Accelerator. I have been given diminsions for the Spir Gear as followed but don't know how to enter them because there is only a limited amount of values:
Number of teeth........10
Diametric pitch.........9.6
Circulator pitch.........0.32725
Pitch diameter..........1.0416
Outside diameter......1.25
Root diameter...........0.8006
Addendum...............0.10416
Dedendum...............0.10416
Clearance................0.163541
Whole depth............0.22466
Circular thickness....0.163625
Fillet.......................0.03125
Pressure angle........9.00
I enter in the Addendum, Clearance, and Pressure Angle and it says that the values are Ambiguous Inputs. Is there any way that I can create this gear?
P.S. it doesn't matter about the Loads, Material Values, and Inputs in the Calculations tab.
