Does anyone have any experiences/explanation for the following problem?
In the IDW environment, when attempting to create a base view of a spring, I
found that the spring was only visible when set as a shaded view, and then
only the rendering is visible. i.e. no outline. All that is visible when
selecting hidden line or hidden line removed, was the the 2 circular
sectioned ends of the spring (section, not diameter) and no part of the
profile is visible at all. once the faltered base view is created it is
possible to create normal projected views from it, but the base view remains
the same. Even when using the shaded view, that does not show correctly when
printed or saved as a dwf or pdf.
Any help on this would be appreciated.
Derek Burns
