Inventor Forum
Spring in curved slot
3 REPLIES 3
safiredesignengineers
536 Views, 3 Replies
Hey group
I need a compression spring to fit in a curved slot, can this be done with design accelerator and also in simulation?
Regards Adrian
3 REPLIES 3
hi group, So is it possible to build a spring around a curve centre line? this would make designing springs to fit in curved slots a lot easier?
and will this be able to be used in simulation as well?
Adrian
Hi Mike
thanks for your input, however I need more than just the part / graphical representation, I would like the spring to be usable in simulation as well so I can look at the forces and the way it behaves.
It would be good if in simulation and design accelerator a spring could be calculated to start and finish at selcted faces and follow a centre line and then it would follow the curve!
Regards Adrian
