Inventor General
Active Member
Message 1 of 5 (441 Views)
Split Solid Error
441 Views, 4 Replies
09-19-2012 09:30 AM
I'm trying to split a single solid body into 2 solid bodies. The problem is that the body I'm trying to split consists of two separate pieces. I can split a body when it is a single piece no problem, but I'm having the problem when the two pieces are not joined at all.
When I try and split it on the origin plane it gives this error:
"Creating parting line failed. Could not build this Split"
When I try and split it on a work plane lying on one of the pieces it gives this error:
"Creating parting line failed. Modeling failure in ASM. Redefine inputs."
Or, another variation on this erorr:
"Creating parting line failed. Split feature could not create two bodies. Change the Split Tool so that split feature can create two bodies."
Is this possible to do?
Message 2 of 5 (433 Views)
Re: Split Solid Error
09-19-2012 10:01 AM in reply to: __spidey_
That would be two features.
One Extrusion, one Split if it worked.
Multi-body solids use two extrusions New Solid.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Message 3 of 5 (427 Views)
09-19-2012 11:16 AM in reply to: JDMather
I see you are using 2010 - so your screen will look different than mine, but
create first extrusion of only one box.
Make sketch visible
Create second extrusion and click the New Solid icon below join, cut, intersect
or
Mirror the original box and select New Solid.
Active Member
Message 4 of 5 (423 Views)
09-19-2012 11:19 AM in reply to: JDMather
Thanks. Yes, that makes sense. For the actual part I'm working with, I need to rethink my workflow so that I use multiple extrusions using the new solids command instead of making the entire part, then trying to split it after.
Message 5 of 5 (419 Views)
09-19-2012 11:24 AM in reply to: __spidey_
I started to type up a work-around, but then deleted it.
As Mike Holmes would say, "Just do it right from the start."
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
