Inventor General
Active Contributor
leech10
Message 1 of 5 (272 Views)
Spline
272 Views, 4 Replies
11-11-2012 10:50 AM
Hello
I made clutch disc. I drawn it in and at the beginning I had a problem with revolve function. Finally I used sketch doctor and I did my part. I wanted to add spline and now problem occured. I cannot select one of the surfaces The end one in screenshot highlighted by red arrow.( I attached second screenshot when face for creation of spline can be selected, but why this end one cannot be?).
How can I amend my project to be able to add the spline. I think problem is with sketch creation and sketch doctor. I drawn this part by drawning one line, clicking Ok then second, then third etc. then I connected evberything with the sketch docotr( closing loops and doing constraints)
I made this element before but I drawn it at once( then spline could be made), not by drawing separate lines, however I would like to be able to draw it with separate lines which I need to connect as it is good for me to add curves or circular shaper. please help me with solving this issue
Regards
Peter
JDMather
Message 2 of 5 (266 Views)
Re: Spline
11-11-2012 11:04 AM in reply to: leech10
Can you attach the ipt file here?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Contributor
leech10
Message 3 of 5 (246 Views)
Re: Spline
11-11-2012 02:43 PM in reply to: leech10
Hi
Please see attached
Regards
Piotr
JDMather
Message 4 of 5 (244 Views)
Re: Spline
11-11-2012 02:56 PM in reply to: leech10
Your sketch  is not constrained.
The centerline is not horzontal.
The small line at right end in image is not vertical - resulting in a face that is not planar when you Revolve.
I recommend you start here http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
A proper sketch (and designed for manufacture part) should look something like this.
Active Contributor
leech10
Message 5 of 5 (205 Views)
Re: Spline
11-12-2012 02:18 AM in reply to: leech10
<p>Hi<p><br><p><br><p><br><p>Thank you I finished my project
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
