Inventor Forum
Spiral metal plate?
3 REPLIES 3
711 Views, 3 Replies
Spiral metal plate?
Anyone know how I would make the attached image?
The plate should be .25" thick.
I've messed around with the helix - spiral function but it always makes a spiral that is already extruded as opposed to just giving me a spiral (like in a sketch) that I can then use another way..  <-- See image.
Thanks in adavece.
3 REPLIES 3
hosford
extrude a circle, extrude cut the slice (pie shape) sketch on slice face, spiral cut using the coil command.
Thaddeus Hosford
NUC9i9QNX i9-9980HK, Win 10 Pro 64
Nvidia GTX 1650
Inventor 2021
in reply to: hosford
I don't get the "spiral cut using the coil command" part..
JDMather
See attached image.
Attach your file here if you can't figure it out.
