Inventor General
New Member
Message 1 of 4 (371 Views)
Spiral metal plate?
371 Views, 3 Replies
10-22-2012 06:26 PM
Anyone know how I would make the attached image?
The plate should be .25" thick.
I've messed around with the helix - spiral function but it always makes a spiral that is already extruded as opposed to just giving me a spiral (like in a sketch) that I can then use another way..  <-- See image.
Thanks in adavece.
Valued Contributor
Message 2 of 4 (346 Views)
Re: Spiral metal plate?
10-22-2012 10:21 PM in reply to: ewolfy
extrude a circle, extrude cut the slice (pie shape) sketch on slice face, spiral cut using the coil command.
M6700, Nvidia K3000M, 32GB, 512 SSD
Win 7 Ultimate 64
Inventor 2014
New Member
Message 3 of 4 (342 Views)
10-22-2012 10:43 PM in reply to: hosford
I don't get the "spiral cut using the coil command" part..
*Expert Elite*
Message 4 of 4 (292 Views)
10-23-2012 04:42 AM in reply to: ewolfy
See attached image.
Attach your file here if you can't figure it out.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
