I have a tube which I'm adding a pocket to the outside by removing some material. I then need to array that around the tube. However I need to offset each pocket along the length of the tube. I've attached the tube with one pocket (v2013) and a picture showing the pattern if the surface of the tube was unwraped.
I can not think of a simple means to doing this and there may not be, but some input would be great either way.
Solved by JDMather. Go to Solution.
Curve Driven Pattern (see attached)
that and more here ------- http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
