Inventor General
Message 1 of 3 (389 Views)
Spiral Pattern for a Feature
389 Views, 2 Replies
11-21-2012 08:17 AM
I have a tube which I'm adding a pocket to the outside by removing some material. I then need to array that around the tube. However I need to offset each pocket along the length of the tube. I've attached the tube with one pocket (v2013) and a picture showing the pattern if the surface of the tube was unwraped.
I can not think of a simple means to doing this and there may not be, but some input would be great either way.
Message 2 of 3 (375 Views)
Re: Spiral Pattern for a Feature
11-21-2012 10:28 AM in reply to: pball
Curve Driven Pattern (see attached)
that and more here -------  http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Message 3 of 3 (354 Views)
11-21-2012 12:35 PM in reply to: JDMather
Thanks for the info. A curve driven pattern is exactly what I needed.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
