Inventor Forum
Spiral Pattern for a Feature
2 REPLIES 2
pball
1489 Views, 2 Replies
I have a tube which I'm adding a pocket to the outside by removing some material. I then need to array that around the tube. However I need to offset each pocket along the length of the tube. I've attached the tube with one pocket (v2013) and a picture showing the pattern if the surface of the tube was unwraped.
I can not think of a simple means to doing this and there may not be, but some input would be great either way.
2 REPLIES 2
JDMather
in reply to: pball
Curve Driven Pattern (see attached)
that and more here -------  http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
pball
in reply to: JDMather
Thanks for the info. A curve driven pattern is exactly what I needed.
