Inventor General
Message 1 of 7 (709 Views)
Spiral (Coil) from the Axis
709 Views, 6 Replies
05-25-2011 05:05 PM
I want to create a Spiral (Coil) that starts from a centre axis and revolve's three times with a pitch of 9.5mm.  My problem is that Inventor 2010 complains that the Axis Intersects Profile which is what I want.  Does anyone out there have a work around or a solution.  I have been trying to create this using the coil command.  The sketch contains a profile on the axis
Employee
Message 2 of 7 (696 Views)
Re: Spiral (Coil) from the Axis
05-25-2011 07:43 PM in reply to: alan.rackham
Do you want to create a Spiral coil with 0mm start radius?
Allen Bai
Senior User Experience Designer
Design, Lifecycle & Simulation
Message 3 of 7 (687 Views)
05-25-2011 08:31 PM in reply to: Allen.Bai
Yes I want to create a spiral with a zero start radius.  I tried your Helical Curve in #D Sketch idea, but get a self intersecting error.
Employee
Message 4 of 7 (646 Views)
05-26-2011 07:31 PM in reply to: alan.rackham
It seems "zero start radius" spiral curve or coil cannot be created in Inventor. Entering 0mm for Diameter is treated as invalid expression when creating spiral curve, although it is actually not self intersecting.
I just try a very close zero value (0.00001), it works! or you can consider to import a 0-start spiral curve from AutoCAD to Inventor and then do some further operation.
Hope is helps.
Allen Bai
Message 5 of 7 (644 Views)
05-26-2011 07:47 PM in reply to: Allen.Bai
Yes I had considered using AutoCAD to generate the solid, but I am not sure how I go about bringing that into Inventor and performing a subtraction of the AutoCAD solid from the Inventor part.  Can you help here...
Employee
Message 6 of 7 (638 Views)
05-26-2011 09:39 PM in reply to: alan.rackham
You can directly open the AutoCAD file in Inventor and then save it as Inventor data; or, you can import the file into an existing opened Inventor part file via "Manage->Import"; or, you can just place the file into an existing Inventor assembly file as component.
Allen Bai
Message 7 of 7 (626 Views)
05-27-2011 03:39 AM in reply to: alan.rackham
Attach your file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
