Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
@kent_wold - this post has been edited.
I found this from Imaginit when attempting a spiral chain pattern... it worked for me!
Hi! The procedure in the document is valid. One thing changes in more recent releases is the ability to create variable-pitch and variable-radius helix. You can easily create such curve without having to create a surface body. Then you can use it a pattern direction.
Many thanks!
Yes I found the Helix 3D operation to be reasonably easy with the improvements to 3D sketching in Inventor over the past few years.
Following the path involved expanding the window for the advanced options which is a procedure I am trying to remember on my own even with some of the simpler more often used commands.
Advanced options open a huge window of opportunity that most of us accidentally ignore!
