Inventor General
Active Member
Message 1 of 9 (187 Views)
Spacebar for panning and scroll wheel for orbit
187 Views, 8 Replies
02-18-2014 02:24 AM
Can you please tell me how i configure my Inventor 2014 to use spacebar to activate panning like autocad 2014 and use the scroll wheel click + mouse move for orbiting the part?
At the moment i have all most all my design software to utilise spacebar as panning and it's a real disruption to the workflow.
Thanksm very much appreciated.
Austin
Distinguished Mentor
Message 2 of 9 (178 Views)
Re: Spacebar for panning and scroll wheel for orbit
02-18-2014 02:34 AM in reply to: austinhall
Hi!!
The space bar is used in Autodesk Software to use like "Enter" or repeat the last command.
It's a "system Key", youy can't change the setting.
You can use the mouse wheel to do panning, rotate and zoom, why using the space bar?!!
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CarlosC
Autodesk Factory Design Suite Ultimate 2014
Autodesk Simulation Mechanical
Autodesk Simulation CFD
Windows 7
Active Member
Message 3 of 9 (176 Views)
02-18-2014 02:40 AM in reply to: carloscarreiras8703
Hi, thanks for your quick response. So far no one can provide the answer if this is possible or not only to change the way i work.
If its possible to change the spacebar to pan i would like to do it, i understand there are other ways of doing things that others may prefer too and this is something i would prefer.
I have been into the customize toolbar and can select pan and enter 'spacebar' next to it but nothing seems to change.
Austin
Message 4 of 9 (172 Views)
02-18-2014 02:47 AM in reply to: austinhall
Hi!
No, you can't.
Regards.
CarlosC
Windows 7
JoAnn_Hogan
Message 5 of 9 (161 Views)
02-18-2014 03:23 AM in reply to: austinhall
Hi There,
You can assign your own shortcut keys like you have them in AutoCAD. Go to your Tools tab > Customize command.
In the keyboard tab find the command you want to customize (like pan) and assign a new shortcut key.
Unfortunately you are not able to assign <Spacebar> as a shortcut key or the mouse wheel. But you can use other keys instead
Please let me know if this helps
Jo (P.S follow me on twitter @JoAnn_Hogan)
If this post solved your issue please mark as solved and Kudos are always welcome =)
AutoCAD Certified Professional 2014 / Inventor Certified Professional 2014
Message 6 of 9 (152 Views)
02-18-2014 03:30 AM in reply to: austinhall
I think most here will recommend you get a 3D Connexion device.
Are you aware that Hold Mouse Wheel is Pan?
Are you aware that Shift Mouse Wheel is Orbit?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
JoAnn_Hogan
Message 7 of 9 (148 Views)
02-18-2014 03:33 AM in reply to: JDMather
And just throwing it in there, if you want your zoom to be the same is in AutoCAD you can change the zoom direction.
Application Menu (Big I) > Options > Display Tab > Reverse direction
Active Member
Message 8 of 9 (140 Views)
02-18-2014 03:43 AM in reply to: JDMather
Hi, thanks yes i'm aware of those combinations.
I jut had a good way of working in Autocad 2014 and Solidworks and as i'm making the transition to Inventor i thought i could adjust the environment acordingly.
Thanks very helpful. Also using Inventor 2014 on parallels on Mac so really this is about minimising the variables to using this software within that envirnoment with the Mac keyboard and mouse and other software like CS6 and Autocad 2014.
Thanks.
Everything is running smoothly.
Distinguished Contributor
chad38
Message 9 of 9 (112 Views)
02-18-2014 07:06 AM in reply to: austinhall
You use a mac? Well that stinks. Are they finally able to run things like inventor and solid edge and works WITHOUT having to do that bootcamp to windows thing?
Cybertron PC
Intel Core i5-3470 CPU @ 3.20 GHz 3.60 GHz
16.0 GB RAM
Windows 7 Professional 64 Bit
3D Connexion Space Pilot
Autocad Mechanical 2014
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
