P.S. You can not simulate mouse clicks on the keyboard, which means you can not
have macros that need a mouse action.
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
"Dave Jacquemotte" wrote in message
news:F5D36DA0DBCA1582D1F8C765548322D8@in.WebX.maYIadrTaRb...
> Use the ALT key. Notice how the menu titles have one of the letters
underlined?
> Well, if you hit ALT- it will bring up that menu. Then, just type
> in the letter on that menu corresponding to action you want. So, for example,
> View isometric would be Alt-vs., I
> So, when you are creating the macro, just type the buttons in exactly like you
> would if doing it in Inventor.
> Dave Jacquemotte
> Automation Designer
> www.autoconcorp.com
> "Finnur P. Frodason" wrote in message
> news:6C3846629ED2E73B409B9BE03BE11C1F@in.WebX.maYIadrTaRb...
> > Thanks to all of you but this I all know.
> > What I wanted to know is how to finds out what the keystrokes are if you do
> > a RMB and select from a menu f.ex Isometric.
> > Are the Inventor menus documentet somewhere?
> > I am so old fashioned that I prefer books to "ebooks" 🙂
> > Finnur
> > news:CED7CDDE990CFEA4A227E512DDA463B7@in.WebX.maYIadrTaRb...
> > > RMB on the icon in the task-tray and click "Open Window". (3DxWare for
> > _____
> > > should say Inventor) In the left box there is a option called "User
> > Macros"
> > > Expand that. RMB on any of the existing Macros and click "Edit User Macro"
> > See
> > > how it looks?
> > > To create your own...RMB on "User Macro" and hit "Add User Macro". Then,
> > just
> > > type in the keystrokes as you would in Inventor. (If you need, you can
> > switch
> > > over and actually do the keystrokes to make sure you are doing it right.)
> > Call
> > > is something useful. Hit save. Then drag the newly formed Macro into the
> > button
> > > location you want (1, 2, 3...) (BTW, it says this at the bottom of the
> > window.)
> > > Dave Jacquemotte
> > > Automation Designer
> > > www.autoconcorp.com
> > > news:4D5B077FE25264647C8C24C1860373EE@in.WebX.maYIadrTaRb...
> > > > Where can I find a list of the key combinations and what they do?
> > > > I have tried in wain on the 3Dconnextion site
> > > > Finnur P.
> > > > news:04CDD0EBBDABB76DEC50AD784F305A58@in.WebX.maYIadrTaRb...
> > > > > When you Open the 3dConnexion window, what is in the application
> > > > drop-down?
> > > > > (3dxWare for ????????) If should say Inventor. If not, you will not be
> > > > able to
> > > > > assign macros to buttons. As a mater of fact, you should re-load the
> > > > driver. If
> > > > > it does say Inventor there, it is working properly. However you will
> > only
> > > > be
> > > > > able to set macros to do things you can do with your keyboard (i.e.
> > menu
> > > > > options, hotkeys, Alt-commands). You can not start icons or hidden
> > > > commands with
> > > > > Buttons. And you can not program now hotkeys.
> > > > > Dave Jacquemotte
> > > > > Automation Designer
> > > > > www.autoconcorp.com
> > > > > "J.CROTEAU" wrote in message
> > > > news:f17a22c.-1@WebX.maYIadrTaRb...
> > > > > > Were can I find information or training file or video file that can
> > help
> > > > me
> > > > > understand how I'm suppose to work with my spaceball. Also I don't
> > know
> > > > how to
> > > > > configure my spaceball, for exemple tell me how I can my spaceball
> > make a
> > > > > pattern component. Thank you
