Got it 🙂 Thanks to all of you
Finnur P.
"Dave Jacquemotte" wrote in message
news:0A59EA2573125F05548DD70D329478A1@in.WebX.maYIadrTaRb...
> P.S. You can not simulate mouse clicks on the keyboard, which means you
can not
> have macros that need a mouse action.
> Dave Jacquemotte
> Automation Designer
> www.autoconcorp.com
> news:F5D36DA0DBCA1582D1F8C765548322D8@in.WebX.maYIadrTaRb...
> > Use the ALT key. Notice how the menu titles have one of the letters
> underlined?
> > Well, if you hit ALT- it will bring up that menu. Then,
just type
> > in the letter on that menu corresponding to action you want. So, for
example,
> > View isometric would be Alt-vs., I
> > So, when you are creating the macro, just type the buttons in exactly
like you
> > would if doing it in Inventor.
> > Dave Jacquemotte
> > Automation Designer
> > www.autoconcorp.com
> > "Finnur P. Frodason" wrote in message
> > news:6C3846629ED2E73B409B9BE03BE11C1F@in.WebX.maYIadrTaRb...
> > > Thanks to all of you but this I all know.
> > > What I wanted to know is how to finds out what the keystrokes are if
you do
> > > a RMB and select from a menu f.ex Isometric.
> > > Are the Inventor menus documentet somewhere?
> > > I am so old fashioned that I prefer books to "ebooks" 🙂
> > > Finnur
> > > news:CED7CDDE990CFEA4A227E512DDA463B7@in.WebX.maYIadrTaRb...
> > > > RMB on the icon in the task-tray and click "Open Window". (3DxWare
for
> > > _____
> > > > should say Inventor) In the left box there is a option called "User
> > > Macros"
> > > > Expand that. RMB on any of the existing Macros and click "Edit User
Macro"
> > > See
> > > > how it looks?
> > > > To create your own...RMB on "User Macro" and hit "Add User Macro".
Then,
> > > just
> > > > type in the keystrokes as you would in Inventor. (If you need, you
can
> > > switch
> > > > over and actually do the keystrokes to make sure you are doing it
right.)
> > > Call
> > > > is something useful. Hit save. Then drag the newly formed Macro into
the
> > > button
> > > > location you want (1, 2, 3...) (BTW, it says this at the bottom of
the
> > > window.)
> > > > Dave Jacquemotte
> > > > Automation Designer
> > > > www.autoconcorp.com
> > > > news:4D5B077FE25264647C8C24C1860373EE@in.WebX.maYIadrTaRb...
> > > > > Where can I find a list of the key combinations and what they do?
> > > > > I have tried in wain on the 3Dconnextion site
> > > > > Finnur P.
message
> > > > > news:04CDD0EBBDABB76DEC50AD784F305A58@in.WebX.maYIadrTaRb...
> > > > > > When you Open the 3dConnexion window, what is in the application
> > > > > drop-down?
> > > > > > (3dxWare for ????????) If should say Inventor. If not, you will
not be
> > > > > able to
> > > > > > assign macros to buttons. As a mater of fact, you should re-load
the
> > > > > driver. If
> > > > > > it does say Inventor there, it is working properly. However you
will
> > > only
> > > > > be
> > > > > > able to set macros to do things you can do with your keyboard
(i.e.
> > > menu
> > > > > > options, hotkeys, Alt-commands). You can not start icons or
hidden
> > > > > commands with
> > > > > > Buttons. And you can not program now hotkeys.
> > > > > > Dave Jacquemotte
> > > > > > Automation Designer
> > > > > > www.autoconcorp.com
> > > > > > "J.CROTEAU" wrote in message
> > > > > news:f17a22c.-1@WebX.maYIadrTaRb...
> > > > > > > Were can I find information or training file or video file
that can
> > > help
> > > > > me
> > > > > > understand how I'm suppose to work with my spaceball. Also I
don't
> > > know
> > > > > how to
> > > > > > configure my spaceball, for exemple tell me how I can my
spaceball
> > > make a
> > > > > > pattern component. Thank you
