Inventor Forum
Sort by Part Number
12 REPLIES 12
Message 1 of 13
KenGundel
479 Views, 12 Replies
Sort by Part Number
With all my weeks of IV (2008 SP0) experience, I'm stuck trying to sort my parts list by part number. I would like, and expect, 10 to follow 9, but 10 follows 1. The order went 1, 10, 11, 2, 3, 4... I got no satisfaction from the new search, although previously it worked great to access all the info here. Can the numbers be sorted numerically?
Thanks in advance for any help.
Ken
I did try a jpg but got an upload error...
12 REPLIES 12
Message 2 of 13
mflayler2
in reply to: KenGundel
Right Mouse Button on your Parts List and go to "Edit Parts List". Click the A to Z button and sort based on Item.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 3 of 13
10 will follow 09 in a sort pattern. The problem
starts with the field justifaction being a LH fill of the file and not a RH
fill. Because the field is alpha-numeric, it is set for LH fill and not a
numeric only field that is set for RH fill/justification.
IV2009-Pro Sp1
Dell 670 dual Xeon - 3.2
3gb memory,
SCSI320-15k rpm
XP-Pro, sp3
Quadro FX3400: Driver: 174.06
Direct3D
SpacePilot Rel V: 3.6.7 Dvr V: 6.6.1 Firmware 3.12
With
the numbers be sorted numerically? Thanks in advance for any help. Ken I did
Message 4 of 13
KenGundel
Item 1 is pn 1, item 2 is pn 10, 3 is 11, 4 is 2, etc. Item sort had no effect unfortunately. What's up with that, overlooking something obvious here....
Message 5 of 13
KenGundel
Changing 1 to 01 etc sorted much more better, thanks to all who helped!
Message 6 of 13
No, that's how it works. It's very annoying indeed.
Side note to Mark. Parts List is better to sort out by Parts Number first,
IMO. Subject that parts are numbered in a logical order. Besides, in a
complex assembly some of the parts may be added later but in a Parts List
they should appear on a top of the list, not in the middle or the end of it.
But with half cooked sort out functionality of the Parts List it is a time
consuming task.
Igor.
To reply please use igor@iinet.net.au address
wrote in message news:6040994@discussion.autodesk.com...
here....
Message 7 of 13
Installing the latest service packshould fix this issue
> my parts
> follows 1.
> search,
> numbers
> be sorted numerically? Thanks in advance for any help. Ken I did try a
> jpg but
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Message 8 of 13
KenGundel
I was wondering if the service packs would help, still getting this system up to speed, but approaching with caution...Thanks!
Message 9 of 13
Did you actually tried it?
Igor.
"MattH" wrote in message
news:6041349@discussion.autodesk.com...
> my parts
> follows 1.
> search,
> numbers
> jpg but
Message 10 of 13
KenGundel
No, still at 2008 SP0, I may be doing some downloading/updating, then see what happens. Then go for 2009, right?! I somewhat hesitant, with no other issues yet, if it ain't broke...
Message 11 of 13
Well, I use IV2008 SP3. The sort by Parts Number is as dysfunctional as it
was in IV7.
Igor.
wrote in message news:6041679@discussion.autodesk.com...
Message 12 of 13
Inv_kaos
It works perfectly in INV2009 SP1...Well about as perfect as it has in the past..
Stew
Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful.
Stew, AICP
Inventor Professional 2013, Autodesk Simulation Multiphysics 2013
Windows 7 x64 Core i7 32GB Ram FX2000
Message 13 of 13
Are you telling me that in IV2009 the parts N°N° 01-GA-1, 01-GA-2,...
01-GA-10 will get sorted out properly, not like 01-GA-1, 01-GA-10...,
01-GA-2?
Igor.
wrote in message news:6042276@discussion.autodesk.com...
past.. Regards, Stew
