Inventor General
Distinguished Contributor
Message 1 of 13 (75 Views)
Sort by Part Number
75 Views, 12 Replies
09-29-2008 11:32 AM
With all my weeks of IV (2008 SP0) experience, I'm stuck trying to sort my parts list by part number. I would like, and expect, 10 to follow 9, but 10 follows 1. The order went 1, 10, 11, 2, 3, 4... I got no satisfaction from the new search, although previously it worked great to access all the info here. Can the numbers be sorted numerically?
Thanks in advance for any help.
Ken
I did try a jpg but got an upload error...
*Expert Elite*
Mark_Flayler
Message 2 of 13 (75 Views)
Re: Sort by Part Number
09-29-2008 11:49 AM in reply to: KenGundel
Right Mouse Button on your Parts List and go to "Edit Parts List". Click the A to Z button and sort based on Item.
Mark Flayler Application Engineer - Manufacturing Solutions Division
IMAGINiT's Manufacturing Solutions Blog:
http://blogs.rand.com/manufacturing/
*Blair Stunder
Message 3 of 13 (75 Views)
09-29-2008 11:53 AM in reply to: KenGundel
10 will follow 09 in a sort pattern. The problem
starts with the field justifaction being a LH fill of the file and not a RH
fill. Because the field is alpha-numeric, it is set for LH fill and not a
numeric only field that is set for RH fill/justification.
IV2009-Pro Sp1
Dell 670 dual Xeon - 3.2
3gb memory,
SCSI320-15k rpm
XP-Pro, sp3
Quadro FX3400: Driver: 174.06
Direct3D
SpacePilot Rel V: 3.6.7 Dvr V: 6.6.1 Firmware 3.12
With
the numbers be sorted numerically? Thanks in advance for any help. Ken I did
Message 4 of 13 (75 Views)
09-29-2008 11:54 AM in reply to: KenGundel
Item 1 is pn 1, item 2 is pn 10, 3 is 11, 4 is 2, etc. Item sort had no effect unfortunately. What's up with that, overlooking something obvious here....
Message 5 of 13 (75 Views)
09-29-2008 11:59 AM in reply to: KenGundel
Changing 1 to 01 etc sorted much more better, thanks to all who helped!
*Igor Mironenko
Message 6 of 13 (75 Views)
09-29-2008 06:08 PM in reply to: KenGundel
No, that's how it works. It's very annoying indeed.
Side note to Mark. Parts List is better to sort out by Parts Number first,
IMO. Subject that parts are numbered in a logical order. Besides, in a
complex assembly some of the parts may be added later but in a Parts List
they should appear on a top of the list, not in the middle or the end of it.
But with half cooked sort out functionality of the Parts List it is a time
consuming task.
Igor.
To reply please use igor@iinet.net.au address
wrote in message news:6040994@discussion.autodesk.com...
here....
*MattH
Message 7 of 13 (75 Views)
09-30-2008 12:52 AM in reply to: KenGundel
Installing the latest service packshould fix this issue
> my parts
> follows 1.
> search,
> numbers
> be sorted numerically? Thanks in advance for any help. Ken I did try a
> jpg but
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Message 8 of 13 (75 Views)
09-30-2008 03:49 AM in reply to: KenGundel
I was wondering if the service packs would help, still getting this system up to speed, but approaching with caution...Thanks!
*Igor Mironenko
Message 9 of 13 (75 Views)
09-30-2008 07:39 AM in reply to: KenGundel
Did you actually tried it?
Igor.
"MattH" wrote in message
news:6041349@discussion.autodesk.com...
> my parts
> follows 1.
> search,
> numbers
> jpg but
Message 10 of 13 (75 Views)
09-30-2008 08:06 AM in reply to: KenGundel
No, still at 2008 SP0, I may be doing some downloading/updating, then see what happens. Then go for 2009, right?! I somewhat hesitant, with no other issues yet, if it ain't broke...
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
