Inventor Forum
Solidworks 2012 SLDASM to Inventor Pro 2013 Fails
14 REPLIES 14
Message 1 of 15
aparrow
1084 Views, 14 Replies
I have been given a bunch of SolidWorks 2012 SLDASM, including the SLDPRT making them up. Inventor Pro 2013 will open the SLPPRT with no problems. However the SLDASM files fail. Well sort of fails. Inventor creates a IAM file that is blank. I've attached a screenshot of log file. The files do infact exist.
Any ideas?
Inventor 2012/2014 Certified Professional
Product/Factory Design Suite 2018
Vault Workgroup & Pro 2018
Dell T7610 - Dual Xeon @ 2.5GHz / 64GB Ram / ATI FirePro W7000 / 512GB SSD & Dual 1TB 10k RPM
Dell M7710 - Core i7 2.7GHz / 64GB Ram / AMD FirePro W5170M / Dual 512GB SSDs
Windows 10 64-bit
14 REPLIES 14
Message 2 of 15
aparrow
in reply to: aparrow
Forgot to mention Fusion 2013 does the same thing.
Windows 10 64-bit
Message 3 of 15
Cadmanto
Are you doing this through the open screen and changing your file type to sldasm?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 15
aparrow
in reply to: Cadmanto
I've tried FILE ->OPEN and changed file type. I also have tried Task Manager. Both with same results.
Windows 10 64-bit
Message 5 of 15
Cadmanto
I have to tell you, and this is coming from experience, when ever I have had to do what you are looking to do I have never had good luck bringing in assemblies from one system into another.  Whether it was SW to Pro-E, or SW into Inventor.  I usually ended up being an incompatibility issue.  Depending on what you are looking for the final outcome to be, you might just want to reassemble the parts that you seem to be successful in importing in Inventor.  Or have the SW files exported out as stp or igs files.
Probably not what you wanted to hear.
Best Regards,
Scott McFadden
Message 6 of 15
JDMather
Can you zip and attach the two *.sldprt files that you are getting errors on?
The CADWhisperer YouTube Channel
Message 7 of 15
aparrow
Attached is one of the small asm files with only 2 parts. And yes I know if would be very easy to just rebuild again. But I'm not rebuilding the 1000 part asm.
I've already requested a STEP file from the provider of the Solidworks files.
Would still ike to know the issue however.
Thanks!
Windows 10 64-bit
Message 8 of 15
aparrow
I've added the IAM/IPT files I get when opened as well.
Windows 10 64-bit
Message 9 of 15
rdyson
The sldasm opened fine in 2014. It seems you're using 2013. Is it possible the sldprt's were created in an earlier version of SW than the sldasm. Just speculating here.
PDSU 2016
Message 10 of 15
aparrow
in reply to: rdyson
I don't have 2014 - yet! That was going to be my next try. I also opened the sldasm's up in the free Solidworks 2012 Viewer just fine.
Windows 10 64-bit
Message 11 of 15
JDMather
One of the parts was an imported solid in SolidWork, but it passed import diagnostics.
Not sure what the problem could be on your end (I don't have 2013).
Message 12 of 15
KevinLi-Autodesk
Hi aparrow,
Thanks for reporting this issue in this forum !
I have done some validations and below is my observations for your reference.
I open your model in Inventor 2013 and do see nothing is imported, then I open its translation report and it says two parts could not be found during translation, so I suppose the relationship between the assembly and parts are corrupt. Thus I open your model in SolidWorks 2012 SP0, backup it again (using save all command), then open it again in Inventor 2013, it works then.
Please try the attached updated model to check if it work in your side.
Have a nice day !!!
Kevin-Hongyuan Li
HongyuanDotLiAtAutodeskDotcom
Quality Assurance Team
Autodesk, Inc.
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
Autodesk, Inc.
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Message 13 of 15
aparrow
in reply to: KevinLi-Autodesk
Yes they opened - but then Inventor crashed as soon as the IAM was loaded on the screen.
So I would think it's a linking issue wuth the Solidworks files and not an Inventor issue.
Thanks to everyone for all the input!
Windows 10 64-bit
Message 14 of 15
KevinLi-Autodesk
Hi aparrow,
Appreciate your valuable feedback !!!
I open my updated SolidWorks assembly file several times in my Inventor 2013 RTM version and unfortunately I don't see the crash. I will keep it in my head once reproduce it, I will investigate it deeply.
I just backup the IAM files via my Inventor 2013 RTM for your reference if you want to use it.
Have a nice day !
Kevin-Hongyuan Li
Autodesk, Inc.
Kevin-Hongyuan Li
Autodesk, Inc.
www.autodesk.com
Message 15 of 15
KevinLi-Autodesk
Sorry, add the IAM attachment.
Kevin-Hongyuan Li
Autodesk, Inc.
www.autodesk.com
