Inventor General
Distinguished Contributor
eveylynne
Message 1 of 3 (233 Views)
Solid Bodies in ilogic
233 Views, 2 Replies
02-12-2014 10:39 AM
I'm driving the colors of solid bodies in a part with ilogic.  I can select each feature, but this is tedious and combersome.  If I change the part, I have to adjust the rule containing tha list of features affected.  I would rather have the rule look at the solid bodies of the part.  I don't know how to call out a solid body in ilogic.
A feature is, "Feature.Color("featurename"), and a component is "Component.Color("part").  This naming scheme doesn't seem to work with bodies though.
What language do I use to modify a body in ilogic?
IV 2014, Windows 7
mrattray
Message 2 of 3 (227 Views)
Re: Solid Bodies in ilogic
02-12-2014 10:56 AM in reply to: eveylynne
I can't seem to find anyway to access solids outside the context of derived parts via the API at all. You might try the Inventor Customization forum.
Mike (not Matt) Rattray
ADN Support Specialist
xiaodong.liang
Message 3 of 3 (182 Views)
02-16-2014 09:42 PM in reply to: eveylynne
you just need to use Inventor API within ilogic. The following is a code demo. For more guide about Inventor API in iLogic, please refer to this course:
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2011/autocad-inventor-suites/autode...
doc = ThisDoc.Document
oDef = doc.ComponentDefinition
'assume there are two appearances in the documents
oGold_Color = doc.Assets("Gold - Metal")
oStones_Color = doc.Assets("Small Uneven Rectanguler Stones - Brown")
'if change all bodies with same color
' in some cases, we need to declare the variable explictly
Dim oSB As SurfaceBody
For Each oSB In oDef.SurfaceBodies
    oSB.Appearance = oGold_Color
Next
' if change specific body to specific color
Dim oSB1 As SurfaceBody
oSB1 = oDef.SurfaceBodies(1)
oSB1.Appearance = oGold_Color
Dim oSB2 As SurfaceBody
oSB2 = oDef.SurfaceBodies(2)
oSB2.Appearance = oStones_Color
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
