Inventor Forum
Solid Bodies in ilogic
2 REPLIES 2
2541 Views, 2 Replies
I'm driving the colors of solid bodies in a part with ilogic.  I can select each feature, but this is tedious and combersome.  If I change the part, I have to adjust the rule containing tha list of features affected.  I would rather have the rule look at the solid bodies of the part.  I don't know how to call out a solid body in ilogic.
A feature is, "Feature.Color("featurename"), and a component is "Component.Color("part").  This naming scheme doesn't seem to work with bodies though.
What language do I use to modify a body in ilogic?
IV 2014, Windows 7
2 REPLIES 2
mrattray
I can't seem to find anyway to access solids outside the context of derived parts via the API at all. You might try the Inventor Customization forum.
Mike (not Matt) Rattray
xiaodong_liang
you just need to use Inventor API within ilogic. The following is a code demo. For more guide about Inventor API in iLogic, please refer to this course:
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2011/autocad-inventor-suites/autode...
doc = ThisDoc.Document
oDef = doc.ComponentDefinition
'assume there are two appearances in the documents
oGold_Color = doc.Assets("Gold - Metal")
oStones_Color = doc.Assets("Small Uneven Rectanguler Stones - Brown")
'if change all bodies with same color
' in some cases, we need to declare the variable explictly
Dim oSB As SurfaceBody
For Each oSB In oDef.SurfaceBodies
    oSB.Appearance = oGold_Color
Next
' if change specific body to specific color
Dim oSB1 As SurfaceBody
oSB1 = oDef.SurfaceBodies(1)
oSB1.Appearance = oGold_Color
Dim oSB2 As SurfaceBody
oSB2 = oDef.SurfaceBodies(2)
oSB2.Appearance = oStones_Color
