Inventor Forum
Snap to geometry on different plane
5 REPLIES 5
tmccar
1313 Views, 5 Replies
I have a sketch on plane XY and I have another plane at an angle, which I would like to work on. How can I create a sketch on the angled plane, using the geometry from the XY sketch and which I can snap to?
5 REPLIES 5
mpatchus
in reply to: tmccar
Try projecting the sketch elements into your new sketch.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
tmccar
in reply to: mpatchus
Hi Mike
  Will you please explain how I do this?
Curtis_Waguespack
in reply to: tmccar
Hi  tmccar,
How to Project Geometery:
http://help.autodesk.com/cloudhelp/2014/ENU/Inventor/files/GUID-5FBFED0C-530B-480A-8DEE-E8B8BF7D385F...
http://help.autodesk.com/cloudhelp/2014/ENU/Inventor/files/GUID-58C2C0CE-63AF-42CE-BAFB-53C9AF248840...
If you need to do this often, you might want to enable the Autoproject edges during curve creation option, found by going to the Tools tab > Applicantion Options button > Sketch tab.
I hope this helps.
Curtis
Thanks Curtis... got tied up in a phone call before I could respond.
Inventor 2025 Beta
tmccar
Thanks, I've got it now - I had been trying to project the geometry to the new plane by doing a 3D sketch - I didn't realise you could project the geometry from withing the sketch.
