Dear folks... yet again.
Now how do I smartest align two assemblys to same center point or distribute even space on 2 sides of the attached par example?
If you Constructed your parts centered about the origin and origin planes. Then
In the assembly, use the constrain tool and constrain the origins. (procedure below)
expand part1 folder
expand part1 origin folder
hit constrain button
pick "Center Point" of part1
expand part2
expand part2 origin folder
pick "Center Point" of part2
then ground them
If the individual parts share an origin, they they will be properly aligned.
If they do not share origin, it is more involved. You will have to create planes in each part and align them.
or constrain with an offset to one edge, though if the part dimensions change later your symetry will be affected.
2014 has a new symetry tool, that should be used if in 2014.
(I havnt tried it yet, look into it)
If they share center planes but not center points (not at same elevation)
then use the same procedure, and instead of center point, constrain the center planes in the same manner
you will have to consider the planes direction in this case however
T.S.
There is several ways to do this:
There are a lot of other ways to do this these are just a few.
Hope this helps.
When you make a part you can make the YZ, XZ, and Xy planes be centered on the part (using the planes as center planes). Or on the 3D model tab under Work features you can add a plane to make it centered.
Tsreagan way is one of the fastest but be careful doing it that way. Make sure your origin planes are centered on both assembles. Also if you change one of the assemblies off to one side of your origin planes then it will not be centered anymore. But no matter what way you do it you have to pay attention to your constraints.
cahoe
If you are just starting out, mastering this tip will help you through the coming years of inventor.
Under the Origin Tab for any part or assembly you will find.
Three planes
Three axis
One Center Point
These are the all important datum objects that ALL inventor files share.
These never move, and cannot be deleted.
If I am making a bolt like object:
When thinking about placing this back into an assembly
The most usable point is the spot where the head meets the shaft.
You can even add offsets just as you do when constraining "screen selected" geometry.
Remember these datum ojects are always there and can help make parts that are easy to constrain.
Not to confuse you but there are many ways to develop the assembly,
You can create the components a part at a time, placed into the assembly after they are created,.
Or model all the components together in one part, then save the pieces as seperate part files.
Or model the parts "In Place" in an assembly.
Read up on these methods now, the approach you choose will greatly affect your process from there.
Reffered to as designing from "BOTTOM UP" or from "TOP DOWN"
This covers it in a lot of detail.
http://en.wikipedia.org/wiki/Top-down_and_bottom-up_design
There are some recources here(the forums) that cover it in the context of inventor.
T.S.
