Inventor General
Active Contributor
Message 1 of 3 (231 Views)
Small file size when exporting
231 Views, 2 Replies
02-15-2013 12:38 PM
I am trying to export and save numerous Inventor Assembly Models, to send to various customers to import into their models. I have been saving them as .stp files, but they are very large files after exporting, and I'd like to know if there is a way to decrease the exported file size. I could zip them after I create them, but I was hoping there was an easier way or different format than .stp. I could also suppress numerous internal componants, but I would rather not have to go through that task either. In the end, they would really only require the outer shell, with any externally viewed holes still present. Any suggestions? Thanks
*Expert Elite*
Message 2 of 3 (217 Views)
Re: Small file size when exporting
02-15-2013 01:42 PM in reply to: kkornocksr
Have you looked into Shrinkwrap in Inventor?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Active Contributor
Message 3 of 3 (183 Views)
02-18-2013 03:57 AM in reply to: JDMather
Thank you for your response. That does shrink the file size quite a bit, altough I was hoping even smaller. However, when I do a stp file of that same shrinkwrap file, the file size enlarges. Do you know why that is? It's not as large as a stp file before I did shrinkwrap, but it is larger than the actually shrinkwrap ipt.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
