I have an assembly which contains some content centre tapered roller bearings. When I do a slice of the entire assembly the bearings remain solid. Within the document settings>modelling tab the "Participate in Assembly and Drawing sections" is checked.
How can I get the part to be sliced within the half sliced view like everything else?
Thank you.
Solved by SBix26. Go to Solution.
