I'm really hoping there's a simple fix for this, but when I'm sketching a spline point by point, the "Ok/Apply" check box window hovers over every cursor point you click. So I tried moving the window, which it does for that point, but the next cursor click it immediately goes back to the original location.
This is really annoying when you accidentally click the 'OK" check box every other click. Is there a way to hide this box when I'm creating a spline?
I'm using Inventor 2014 SP2
At this time there is not a setting that can be turned off for this not to display while sketching a spline, consider posting this in the Ideas forum to be considered to be added to the software.
Don
Actually, probably closer to 11 years.
