Inventor General
Active Contributor
leech10
Message 1 of 4 (235 Views)
Accepted Solution
Sketches in iam files
235 Views, 3 Replies
08-29-2012 11:59 PM
Hello
I am creating cone clutch in Inventor 2013 Student. This is my first thing in Autodesk software. I Created shafts and bearing without problems but now I wanna do clutch cone. I am doing 2D sketch and then I want to revolve it to create 3D part. The problem is that This part is clearly visible in a preview when I am clicking on the sketch and on the revolve button, but after applying settings it disappears! I know that it is there as it covers a bit of the shaft. I attached screenshots to make it clear. I dont know what to do. I've done tutorial with bottle but there it is workig fine, but what i have noticed thare is different kind of project with ipt file. Also I found that I have to select sketch plane. At the beginning I highlighted the shaft as in the picture, then I used XY plane, but it did not solve the problem. Please advise me how to create this clutch cone. I need it also to be fully editable as I need to put it on the shaft , make some connection etc
Cheers
Peter
*Expert Elite*
JDMather
Message 2 of 4 (211 Views)
Re: Sketches in iam files
08-30-2012 04:24 AM in reply to: leech10
Note that in your first picture the preview is red which indicates a Cut operation.
In the real world if you have an assembly of parts - you can only cut material from them (unless using special operations like welding).
If you want to create a part at the assembly level you must select New Part and create the sketch for that part rather than creating the sketch in the assembly level for cutting the assembly.
This should have been covered by your professor.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
*Expert Elite*
harco
Message 3 of 4 (205 Views)
08-30-2012 04:31 AM in reply to: leech10
Features(revolve,extrude,etc.) in an assembly only cut material, this is what is clearly visible.
Look at your Inventor2 jpg it shows the cut through one of the shafts.
You cannot create material in assembly, except weldments (not applicable here).
Everything above your End of Features symbol shows a cutting operation, including fillets.
Start a new part, finish the sketch.
Switch to your assembly, copy the sketch you created in the assembly to make you part.
Switch back to your new part, expand the origin folder and right click on a workplane then paste the sketch.
Constrain and dimension the sketch contents properly.
Create your revolve from the sketch and you should now have your cone.
Save this part.
Go to assembly and place part, then use assembly constraints to fit it all together.
Active Contributor
leech10
Message 4 of 4 (195 Views)
08-30-2012 05:19 AM in reply to: leech10
Thank you very much. Now it is clear for me
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
