Inventor General
Valued Mentor
Ktelang
Message 1 of 3 (163 Views)
Sketched Symbol - ASSEMBLY NUM
163 Views, 2 Replies
04-28-2012 04:01 PM
I have an Assembly X which has subassmblies Y and Z
I have a drawing of assembly X I have a sketch symbol created to show
part number when a leader is attached to a part. How can I show up Y and Z part numbers/assemgly numbers in drawing and not the parts inside Y and Z
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
Product Support
Dennis.Ossadnik
Message 2 of 3 (118 Views)
Re: Sketched Symbol - ASSEMBLY NUM
05-04-2012 04:24 AM in reply to: Ktelang
Hi Ktelang,
the leader text will always display the values of that part you attached your leader to.
But you can solve the issue by using the balloons.
Create a new Balloon Style in Styles Editor and pick the part number to display with the balloon.
After that you can place your balloons and switch to your new balloon style. Now the part number of the assembly is shown. If you select the linear shape in the balloon style your balloon will look like a leader text.
That's the result:
Do you think this would work for you?
If so, please use the button "Accept as Solution".
Dennis Ossadnik
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Valued Mentor
Ktelang
Message 3 of 3 (97 Views)
05-14-2012 08:02 AM in reply to: Dennis.Ossadnik
Thanks Dennis
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
