Inventor General
Member
drafdog
Message 1 of 24 (670 Views)
Sketch will not offset
670 Views, 23 Replies
04-30-2013 12:01 PM
Inventor 2011 will not offset polygon in sketch mode.  I get "Method not supported for transient meta" error message.  How do I fix this problem?  Or what am I doing wrong?
*Expert Elite*
mrattray
Message 2 of 24 (668 Views)
Re: Sketch will not offset
04-30-2013 12:18 PM in reply to: drafdog
I don't have 2011, but it works fine in 2013. Why don't you post the part file here so I (or someone else) can take a look at it?
Mike (not Matt) Rattray
Distinguished Mentor
swhite
Message 3 of 24 (650 Views)
04-30-2013 01:42 PM in reply to: drafdog
Select offset, right-click a line, make sure loop select is checked. If you still have the problem attach the ipt and i'll take a look since am running 2011 and can offset polygons or any shape just fine.
left off constraints to show offset lines easier.
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
Intel Dual Xeon E31225 @ 3.1 GHz CPU
16 GB RAM
NVIDIA Quadro 600 GPU
Windows 7 - 64 Bit
*Expert Elite*
blair
Message 4 of 24 (640 Views)
04-30-2013 04:01 PM in reply to: swhite
Possibly in the Offset, a segment of the line is becomming small enough to that it can no longer exist. This could be the problem as well.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
swhite
Message 5 of 24 (627 Views)
05-01-2013 04:56 AM in reply to: drafdog
As Blair remarked that is one of the most common problems. Did you make the polygon manually or use the polygon shape tool?
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
16 GB RAM
Windows 7 - 64 Bit
*Expert Elite*
Mark_Wigan
Message 6 of 24 (614 Views)
05-01-2013 06:23 AM in reply to: swhite
i just had this happen about 2 minutes ago on a simple circle of all things, using inv 2014.
i had to restart inventor and now it is fine.
btw, i have never ever seen this error before now. i was about to post and see if it was a new bug but saw someone else with the same issue on inv 2012 so i cancelled the post, to then see this one running.
best regards,
- Mark
PDSU 2014 Windows 7, 64bit. (please consider Kudos or Tag as Solved if your issue is sorted)
Member
drafdog
Message 7 of 24 (607 Views)
05-01-2013 06:37 AM in reply to: swhite
Polygon shape tool was used.
swhite
Message 8 of 24 (597 Views)
05-01-2013 06:56 AM in reply to: Mark_Wigan
Had that happen to me before with projected geometry, but at the time was new to Inventor so just thought it was me. Of course since then have done it many times without any problems, so expect its just one of those rare occurrances that glitch out.
drafdog, have you tried making a new polygon and offsetting it in a completely new sketch? Just to see if it works or not?
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
16 GB RAM
Windows 7 - 64 Bit
*Expert Elite*
mrattray
Message 9 of 24 (595 Views)
05-01-2013 06:58 AM in reply to: drafdog
Have you tried a reboot?
*Expert Elite*
JDMather
Message 10 of 24 (593 Views)
05-01-2013 07:01 AM in reply to: drafdog
Why haven't you attached the ipt file here?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
