Inventor Forum
Sketch text parameters inventor 2012
2 REPLIES 2
Fleagle8t
1043 Views, 2 Replies
I have several name plates which are embossed, and only the description changes from job to job, but find it a nuisance having to go into the part,edit sketch then edit text! each time I want to change the description .
I was initially going to get round this by creating a form and linking it to the text parameter!  But for some reason it won't take in the text parameter I created and will only find and take in numerical parameters?
 Is there any way around this? Or am I doing something wrong?, I know it is possible in inventor 2013.
I am currently working with Inventor professional 2012 Any help would be greatly apprieciated.Smiley Happy
2 REPLIES 2
Hi F leagle8t,
Mark Randa has written some ilogic to do help with this. You can find a link and an example file here:
http://forums.autodesk.com/t5/Autodesk-Inventor/Emboss-File-Name-on-Part/m-p/3288659#M422787
As you mentioned Inventor 2013 will do this without the need for iLogic.
I hope this helps.
Curtis
Fleagle8t
in reply to: Fleagle8t
As always Curtis, you have the solution!
Many,Many thanks.
You're a Star.
