Inventor General
*Blair Stunder
Message 1 of 7 (361 Views)
Sketch in Weldment?
361 Views, 6 Replies
10-01-2008 11:26 AM
In a standard IAM you can create a Sketch, but
in a Weldment, you can't in the main IAM enviroment. Did something change, or
was this functionality never there.
IV2009-Pro Sp1
Dell 670 dual Xeon -
3.2
3gb memory, SCSI320-15k rpm
XP-Pro, sp3
Quadro FX3400: Driver:
174.06 Direct3D
SpacePilot Rel V: 3.6.7 Dvr V: 6.6.1 Firmware
3.12
*Blair Stunder
Message 2 of 7 (361 Views)
Re: Sketch in Weldment?
10-01-2008 11:33 AM in reply to: *Blair Stunder
Work-a-round is to have a uncomsumed sketch, but
this requires a separate IPT file.
IV2009-Pro Sp1
Dell 670 dual Xeon - 3.2
3gb memory,
SCSI320-15k rpm
XP-Pro, sp3
Quadro FX3400: Driver: 174.06
Direct3D
SpacePilot Rel V: 3.6.7 Dvr V: 6.6.1 Firmware 3.12
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
but in a Weldment, you can't in the main IAM enviroment. Did something change,
or was this functionality never there.
IV2009-Pro Sp1
3.2
XP-Pro, sp3
174.06 Direct3D
3.12
*Loren Jahraus \(Autodesk\)
Message 3 of 7 (361 Views)
10-01-2008 02:43 PM in reply to: *Blair Stunder
Sketches are enabled when Preparations or Machining
is active.
Loren Jahraus
Autodesk Inventor Product
Design
*Blair Stunder
Message 4 of 7 (361 Views)
10-01-2008 03:48 PM in reply to: *Blair Stunder
But you can't have a sketch in the main IAM
enviroment the same as a standard IAM non-weldment
IV2009-Pro Sp1
3gb memory,
SCSI320-15k rpm
XP-Pro, sp3
Direct3D
Machining is active.
Loren Jahraus
Design
Message 5 of 7 (361 Views)
10-01-2008 04:48 PM in reply to: *Blair Stunder
I believe the sketches are restricted to those
environments In elements because you can't create features at the top
level. What are you using the sketch for? I can add this to our database, but it
helps if I have documentation on the workflow it is supposed to
support..
Loren Jahraus
Design
Distinguished Contributor
duncan
Message 6 of 7 (263 Views)
10-03-2012 02:04 PM in reply to: *Loren Jahraus \(Autodesk\)
Loren,
I appriciate this is an old post, but I got a good reason to have a sketch in a weldment.
To help place a work feature
Take a hollow hemisphere
Make a hole through the shell that is off-centre from the middle, but parallel to the centre line
You have curves in all three dimensions, so placing work planes accurately become difficult
I now need a work point that is in the centre of the hole and aligned with the outside of this hemispherical shell
I also want to put it in with the least number of work features to keep the file size to a minimum.
I would put a work axis down the hole and a work plane between the centre work plane and the one down the hole.
Next I would put a sketch on the work plane a project the geometry
Where the sketch geometry crosed the user work axis I would put a work point.
I'm open to any better suggestions as well
TIA
Duncan Anderson
"Humour is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be as mad as what passes for ordinary living." {Terence 'Spike' Milligan KBE (16 Apr 1918 – 27 Feb 2002)}
New Member
Message 7 of 7 (224 Views)
10-31-2012 01:48 PM in reply to: *Blair Stunder
Sounds like the same thing I'm trying to do.
Workflow is:
Open weldment
Create specific planes for nozzles on tank head ( for repositing on head later)
Place tank head from standards library
Start machining
Create first cut for vessel inlet flange
Create sketch on vent nozzle plane at desired angle
This is to produce a hole cut thru the tank head (for locating the pipe/flange later)
When trying to create an axis and point the workflow comes to a screeching halt
Inventor 2013 will not allow me to perform those tasks
This workflow is more desirous than copying/renaming the standard tank head just to make cutouts.
Then placing that .ipt into a weldment.iam.  What would be the point of having a standard tank head if you can't perform these basic tasks.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
