I have a sketch where the actual dimension isn't displayed anywhere, but it's still in the parameter table and the sketch still responds to changes I make in the table.
I also, in other sketches, deleted dimensions to have them still hanging around in the parameter table and the only way I can delete them is by writing vba code to delete them.
Anybody else seen this before? Is there something I'm missing?
Solved by cwhetten. Go to Solution.
Can you attach a part that shows this behavior?
My first guess is that you have turned off the sketch dimension visibility:
But even if the dimension visibility is off, the dimensions would still be shown when actively editing that sketch. Do your sketch dimensions reappear when you directly edit the sketch (right-click the sketch and choose "Edit Sketch")? If so, it's probably just this option. If not, it may be something else.
Second idea is that you are having some issues with your graphics. What graphics card do you use? Do you have the latest drivers?
As for your second question:
@Anonymous wrote:I also, in other sketches, deleted dimensions to have them still hanging around in the parameter table and the only way I can delete them is by writing vba code to delete them.
Are these parameters being used by other parameters? If so, you can't delete them. But if they aren't being used by other parameters, you should be able to right-click and choose delete. Are you saying that it does not give you the option to delete when you right-click? Or does it give an error when you try? You might have to give some more information on this.
If you can attach a part that exhibits this behavior, that would really help us to help you.
Cameron Whetten
Inventor 2012
Cameron is right. Please check Dimension Visibility issue. If they are set to be visible, I suspect there could be some sort of corruption in the sketch leading to this behavior. If it is the case, please post the file here or send it to me (johnson.shiue@autodesk.com) so I can take a closer look.
Thanks!
Okay - thanks for the replies - sorry for the disappearing act...
The dimensions do display as they should, and visibility is set to Expression.
The part is NOT linked to any other parts or assemblies. I doubt it's a video card issue since all the others do display.
I have attached the part in question...
I actually want the angle dimension back if it's possible, I inherited this thing and it's happened a time or two before so I was hoping there some easy way to bring it back - looks like I may be in for some code work of some sort?
No one else has run across this? I've deleted unrelated dimensions in the past and found them hanging around in the parameters table still - must be something I'm doing, I'm just not sure what...
I see the same thing you do. That angle dimension is there (changing its value updates the sketch accordingly), it's just invisible. It's really strange, and I've never seen something like this before.
You can fix the problem if you delete the line segment shown below:
Deleting this line will also remove the angle dimension. Then you can re-create the line, add your colinear constraint again, and then re-create the angle dimension and rename it back to Angle. I'm not sure why it happened in the first place, but doing this should get you back on track.
Cameron Whetten
Inventor 2012
Please click "Accept as Solution" if this response answers your question.
Or just delete the two constraints as I suggested and add a new parallel constraint to re-constrain.
I tried your suggestion, but it didn't seem to solve the problem. The angle dimension was still invisible, even after re-constraining the geometry. Did the angle dimension reappear when you did it?
Cameron Whetten
Inventor 2012
Hmm... Dragging the line didn't do it either. I deleted the two constraints you highlighted, applied the parallel constraint, then dragged the line--no go. I deleted the two constraints you highlighted, dragged the line, then applied the parallel constraint--no go.
This strange behavior is even stranger if it is different for you than for me.
Cameron Whetten
Inventor 2012
Gotta second cwhetten's findings as well, and agree with rdyson, something must have changed in 2014. Thanks for all the work guys, I appreciate it!
Hi! The behavior is not right. I am not sure when this behavior started. Anyway, I am sending it to development for further review.
Many thanks!
