Inventor Forum
Sketch Point Visibility
5 REPLIES 5
mariont55
5511 Views, 5 Replies
How do I make sketch points visible in drawing, so I can use them for dimensioning ?
This is an old issue, but I have yet to find acceptable solution. I'm trying to dimension features in drawing to a "gauge point". Seems that a "sketch point" would be ideal if there is a way to display points in drawings.
Only way I can do this so far, is to "retrieve" model dimensions into the drawing. However, model dimensions are not always pointing to surfaces I need in the drawing. So I had to put some driven dimensions in the model sketch and then I can retrieve those into the drawing and seems. It is a very awkward way to do things. Plus, there is no marker showing in the drawing where this dimension is pointing to. I really don't want to draw small circles, or extra lines at the gage point locations, not a good way to do things.
(I've circled my sketch points in the attachment)
Is there a proper / proper way to do this ?
5 REPLIES 5
JDMather
in reply to: mariont55
I thought there was a direct way to do this, but now I can't find it.
Here is a way that works -
In the part, make your sketch Visible.
Create WorkPoints at each desired sketch point.
You can make these WorkPoints visible in the drawing.
mariont55
JD,
Works great. Thank you.
nigel_swehla
in reply to: JDMather
I have this issue right now as well, except I can't use anything from a part because I'm just making an alignment target from scratch in a drawing and need a center point to align a laser to.
SBix26
in reply to: nigel_swehla
Here's one workaround:
  • Create a sketch
  • In the sketch, place a circle, dimension it as needed
  • Exit sketch
  • Place a center mark on the sketch circle
  • Edit the sketch and toggle the circle to Sketch Only
  • Exit the sketch-- center mark remains, circle is invisible
Hope that helps,
Sam B
Inventor Pro 2022 | Windows 10 Home 2004
LinkedIn
kimK7B54
in reply to: SBix26
Great suggestion.  I've been drawing a circle and "X" in sketch to leave a work-point to dimension to.  I think your method will work faster.  Thank you.
