Inventor Forum
Sketch Dims Displaying incorrectly
6 REPLIES 6
174 Views, 6 Replies
There was a thread on this the other day but there was no resolution. Now
I'm seeing it too...
See CF same topic.
If you double click on the dim the edit box lists 60deg.
And I serious doubt it's a graphics card issue. Quadro 4 700XGL
Can we log a defect on this one?
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
http://www.sdotson.com/faq.html
6 REPLIES 6
It gets better, see the second post in CF.
That 127.77 deg angle should be 120 (60 x 2) It's not even 47.77*2 which
would be 95.54...
This is going to cause a expensive mistake one day...
Sean Dotson, PE
"Sean Dotson" wrote in message
news:705A1CA923445B368F5133731C7AB52A@in.WebX.maYIadrTaRb...
> See CF same topic.
> Sean Dotson, PE
Same thing WAS happening here. I posted a file to CF and of course when they opened it it worked fine for them. Now I can't even TRY to get it to occur again. See the thread "I have a good one" on Nov. 26. Also, does this problem seem to get worse for you the longer you have IV running? Mine would get so bad the dimension text would be illegible. Using a Quadro 2 Pro.
"Also, does this problem seem to get worse for you the longer you have IV
running? "
I had IV open for 4-5 hours.  This is the
first time in a few months I've seen this in R6 (with and without
SP1)
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Same
Pro.
When I first noticed it the text kept getting pregressively worse the longer IV was open. Haven't seen it since and i've had the same IV session open since 8am. Weird.
Sean
I think i know the culprit.
Can you post that part file?
- Drew
Drew Fulford B.A.Sc. Systems Engineer
Solid Caddgroup Inc. Burlington, Ontario
Tel: (905)331-9670, Fax: (905)331-7280
Corporate: http://www.solidcadcam.com/
Member of the Autodesk Discussion Forum Moderator Program
Visit my MCAD website @ http://www.mymcad.com/
news:94672676B73AFBA5AB73BD9D514E017D@in.WebX.maYIadrTaRb...
running? "
> I had IV open for 4-5 hours. This is the first time in a few months I've
seen this in R6 (with and without SP1)
> Sean Dotson, PE
> "Todd_G" wrote in message
news:f129fba.1@WebX.maYIadrTaRb...
Sure but I've modified it since and once I shut down it fixed itself.
Regardless it's in CF under the same topic. Shoot me an email and let me
know what's up.
Sean Dotson, PE
"Drew Fulford" wrote in message
news:DB9919D08558AAFB201860696AF11CDE@in.WebX.maYIadrTaRb...
> Sean
> - Drew
IV
> running? "
I've
> > Sean Dotson, PE
when
this
would
