Sure but I've modified it since and once I shut down it fixed itself.
Regardless it's in CF under the same topic. Shoot me an email and let me
know what's up.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
http://www.sdotson.com/faq.html
"Drew Fulford" wrote in message
news:DB9919D08558AAFB201860696AF11CDE@in.WebX.maYIadrTaRb...
> Sean
> I think i know the culprit.
> Can you post that part file?
> - Drew
> Drew Fulford B.A.Sc. Systems Engineer
> Solid Caddgroup Inc. Burlington, Ontario
> Tel: (905)331-9670, Fax: (905)331-7280
> Corporate: http://www.solidcadcam.com/
> Member of the Autodesk Discussion Forum Moderator Program
> Visit my MCAD website @ http://www.mymcad.com/
> "Sean Dotson" wrote in message
> news:94672676B73AFBA5AB73BD9D514E017D@in.WebX.maYIadrTaRb...
> > "Also, does this problem seem to get worse for you the longer you have
IV
> running? "
> > I had IV open for 4-5 hours. This is the first time in a few months
I've
> seen this in R6 (with and without SP1)
> > Sean Dotson, PE
> > "Todd_G" wrote in message
> news:f129fba.1@WebX.maYIadrTaRb...
> > Same thing WAS happening here. I posted a file to CF and of course
when
> they opened it it worked fine for them. Now I can't even TRY to get it to
> occur again. See the thread "I have a good one" on Nov. 26. Also, does
this
> problem seem to get worse for you the longer you have IV running? Mine
would
> get so bad the dimension text would be illegible. Using a Quadro 2 Pro.
