> Anyone else see this ??
I haven't. As Jeff says, it sounds like you have a problem with one of your
files. Can you repeat the crash with any of the derived parts (which would
suggest a problem with the master file), or is it just one of them? If it's
just one, I'd try creating a new version of that part and see if that has
the same problem. If it does, I'd look really close at the master file
sketch used to create that part. See my reply to Willy Driessen on 1-7 for
a few things I've found that can cause a sketch to act up. Willy's problem
was long extrude times, but I've also seen that a master file that takes a
long time to compute extrude profiles is also more likely to crash.
If your project is too big to post to CF, be sure to get it to your VAR for
forwarding to Autodesk. The developers are always interested in repeatable
crashes.
Cheers,
Walt
