Inventor General
New Member
Message 1 of 2 (269 Views)
Simulating Torque in Autodesk Inventor or Autodesk Multiphysics
269 Views, 1 Replies
04-27-2012 01:58 PM
Hello Everyone,
I'm currently modeling a screw for a spinal implant for my Senior Design project and I am trying to analyze the amount of torque that it can withstand before breaking. I would like to simulate the screw being inserted into bone and see the pressure that the thread undergoes, however, I've only been able to apply forces along the Z and Y axis.
I would appreciate any help regarding this issue. Thank you very much for your time and help.
Employee
Message 2 of 2 (254 Views)
Re: Simulating Torque in Autodesk Inventor or Autodesk Multiphysics
04-27-2012 05:47 PM in reply to: xalan001
Hi xalan001,
  You can apply a torque load instead of a force, it is labeled as moment.
  I'm not that familiar with bone material, but I assume that the screw threads do not undergo plastic deformation.  It is non-trivial to do a non-linear analysis on threads...as only 2-4 threads hold most of the load at least when we're dealing with metal on metal.
  If you need to include the compliance of bone, I suspect bone may have a non-linear stiffness [Edit: or it is considered a brittle material].  Therefore, this may require Autodesk Mechanical simulation.
Hope this helps...
Hugh Henderson
Simulation QA Engineer
DLS
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
