Inventor General
Active Contributor
Message 1 of 5 (361 Views)
Simple ilogic Rule?
361 Views, 4 Replies
10-26-2012 03:33 AM
Our drawing borders have a Mass on them driven by the physical properties of the model.
We have had issues where the mass on the drawings would read "N/A" when the models were updated. I have partially solved this by altering the settings in the general tab to "update phyiscal properties on save".
This works fine most of the time. However it is still possible to update the model then view the drawing and save it without saving the model first. This results in the "N/A" appearing in the mass box.
Is there a simple way of ensuring the model is saved before the drawing is saved, thus forcing a physical property update?    ilogic perhaps?
Thanks.
Ian Farmery
Inventor 2010 Pro SP4, Vault Collaboration 2010
HP Z820 Xeon E5-2643 0 @ 3.3Ghz 16.0GB RAM
Nvidia Quadro 5000
mrattray
Message 2 of 5 (352 Views)
Re: Simple ilogic Rule?
10-26-2012 04:39 AM in reply to: -ianf-
In the drawing:
1) Create a rule.
2) Insert this line:
 ThisDrawing.ModelDocument.Save
3)  Go to Manage>iLogic>Event Triggers.
4) Add your new rule to the Before Save Document event
Mike (not Matt) Rattray
Active Contributor
Message 3 of 5 (327 Views)
Simple ilogic Rule?
10-29-2012 12:50 AM in reply to: mrattray
Thanks for the response Mike,
Can't get the rule to work.
returns the following ilogic error:
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
We have 2011 sould this be the reason?
Ian Farmery
Nvidia Quadro 5000
mrattray
Message 4 of 5 (311 Views)
10-29-2012 04:40 AM in reply to: -ianf-
Your Inventor version shouldn't be an issue, VBA is VBA. Unfortunately an unspecified error could be anything. Has this model been saved before? The Save method requires that the model have already been saved before. Is the file read-only? Do you have write permission for the location where the file is stored? Is Vault involved? Is the wind blowing from the East? Are you using LOD's?
Active Contributor
Message 5 of 5 (276 Views)
11-01-2012 02:37 AM in reply to: mrattray
Thanks, I see. The file was new and needed an initial save.
Many thanks.
Ian Farmery
Nvidia Quadro 5000
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
